babs 0 Posted May 6, 2017 CAN YOU CONTOUR CUT WITH VINYLMASTER CUT?? Quote Share this post Link to post Share on other sites
Camel 7 Posted May 6, 2017 From the USCutter Product page: (Its not hard to see) Contour Cutting Wizard Add registration marks, print, and cut from 1 screen - with helpful prompts from the software wizard. VinylMaster Cut is equipped to provide precise contour cutting whether your machine works with LAPOS (Laser Positioning Sensor) for manual contour cutting or ARMS (Automatic Registration Mark Sensor) for automatic contour cutting. Contour cutting, cutting the outline around a printed image, is perfected with VinylMaster Cut for applications like stickers and custom printed labels. The GUI that VinylMaster Cut offers provides you with diagrams to preview and modify before completing your contour cuts. This preview will even assist you in loading your media into your cutter correctly. VinylMaster Cut has an advanced feature to allow for sensitivity control over your cutters optical eye when using the ARMS feature. This feature ensures that your registration marks can be read when cutting matte, gloss, laminated or even reflective material. http://www.vinylmasterltr.com/vinylmaster-pro-home/features-and-comparison-list/ You can also try a demo, select which version upon startup, and play around with the features. Quote Share this post Link to post Share on other sites
babs 0 Posted May 7, 2017 thank you very much. i just wanted to make sure i was reading that correct because I bought this software for my laserpoint 24 and i have yet to cut anything with using this software, it works fine with signcut. it does not cut with the contour cutting feature. I have read everything, I have contacted support twice and i still cannot get it to work it does not even attempt to cut. Oh well thats 60 bucks lost. Again thank you so very much. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 7, 2017 Which support have you contacted.. UScutter or Vinyl Master support?...Vinyl Master support has been very active on this forum helping with their software... Quote Share this post Link to post Share on other sites
Camel 7 Posted May 7, 2017 I've received great support from vinylmaster, and haven't messed with the contour part until the last few weeks actually. Are you clicking the "apple" in vinylmaster to start contour cutting? Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 7, 2017 This page has the instructions for Laser Point/ Vinyl Master contour cutting, as well as other soft wares...If you have to print it out, and then check off as you go.each step. There is also a video to help. https://support.uscutter.com/support/solutions/articles/14000030645-laserpoint-2-contour-cutting Quote Share this post Link to post Share on other sites
