newtovinyl 1 Posted December 4, 2016 I am trying to cut 150 of the image below and I am having the following issues. The "C" in Castle cuts off and the "S" in Rockets does the same. Yes I did mess with the pinch roll pressure when I first got my machine. I now know that was a mistake; I just need to know how to fix it. Or if that is even the problem? The vinyl doesn't bunch when feeding through or cutting (except on the left side when facing the machine). I am using 20" material and cutting close to the edge. Also, when I am send this image to the cutter it takes a long time for the TItan to start cutting. Is it my computer or? Any help would be great!! Share this post Link to post Share on other sites
Cal 393 Posted December 4, 2016 Hello, and welcome aboard - if I haven't earlier relayed that to you. What cutting program are you using? Can you post up a pic of what is does, it will help in getting an answer for you. Cal Share this post Link to post Share on other sites
newtovinyl 1 Posted December 4, 2016 I am using VM LTR V4.0. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted December 4, 2016 If you can, post your working file and we'll take a quick look to be sure it's not file related. Share this post Link to post Share on other sites
