michellew58 0 Posted June 21, 2016 Received my 15 X 15 clamshell. Before using for the first time, should I heat it up first? Read on social media that one should do a burn off before bringing it in the house. If yes, what temp and time? Thanks! Share this post Link to post Share on other sites
arty-rc 719 Posted June 21, 2016 I did it to mine. 450 degrees for 5 min should do it. Wipe it down when you're finished. Don't forget to use either a teflon sheet or parchment paper when you start to press shirts. 2 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 21, 2016 There will possibly be some smoke the first time. Like arty says get it good and hot and then wipe it down. If you have an old white shirt or something like that to press a couple times to be sure there is no residue would be smart. 2 Share this post Link to post Share on other sites
michellew58 0 Posted June 21, 2016 Arty-rc Thank you! When you say wipe it down, what am I wiping down, plates, machine, all. Also, with a wet rag, dry rag, etc? Thanks for your guidance Share this post Link to post Share on other sites
michellew58 0 Posted June 21, 2016 Thanks Wild Goose! Share this post Link to post Share on other sites
mfatty500 456 Posted June 21, 2016 Maybe a little rubbing alcohol. 2 Share this post Link to post Share on other sites
