kswqte 8 Posted June 13, 2015 When I am cutting my decal using a Laser Point II with a 60 degree NEW blade - When the cutter gets done with a letter and it is raising up to go to the next letter it seems to just pull a bit on the vinyl causing it to leave a little dot. Best way I can describe it. If you need more info let me know and I will try my best to explain. Also using Oracal 651 Share this post Link to post Share on other sites
rpmrpm 32 Posted June 13, 2015 My guess. Research blade offset and adjust for your new blade. Different brand blades and deg will require different offset settings. Share this post Link to post Share on other sites
kswqte 8 Posted June 13, 2015 I can't seem to find where the LaserPoint II has an offset option. I see speed and pressure only. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 13, 2015 Blade offset is in your cutting software. Share this post Link to post Share on other sites
kswqte 8 Posted June 13, 2015 Found it - Cutter Settings Share this post Link to post Share on other sites
