iam1ofhis 0 Posted April 15, 2015 I was able to get a few templates done with my template material from Specialty Graphics. Now, I'm trying to use Sticky Flock with no success. I've adjusted my blade so a little is exposed or a lot is exposed. I've played with the pressure....anywhere from 225-325 and nothing seems to be working. It's cutting, but not deep enough. Any suggestions on the pressure with this SC series cutter? Thanks! Share this post Link to post Share on other sites
gwynyr 13 Posted April 15, 2015 Have you tried a 60° blade? Share this post Link to post Share on other sites
MZ SKEETER 4,693 Posted April 15, 2015 And from what I have read, it takes a few passes... Share this post Link to post Share on other sites
30-284 86 Posted April 16, 2015 300 grams of pressure should do it in 1 pass, that's all I ever use and never fail to weed all holes at once. that is with a 60 degree blade as well. Donn 1 Share this post Link to post Share on other sites
iam1ofhis 0 Posted April 16, 2015 I am using a 60 degree blade. I noticed I did need to expose more than usual. I'm testing now with speed of 300, pressure of 200, and a double cut. Seems like everything I've read suggests a pressure of 180-200. That's not getting me ANYWHERE. Donn...do you use the SC series? Share this post Link to post Share on other sites
GraphxNMore 282 Posted April 16, 2015 60* blade and multicut of 2. No need to have that much pressure. I run mine on about 125 with extra blade. What I hate is when the debitage from the template works its way into the holder. 1 Share this post Link to post Share on other sites
30-284 86 Posted April 16, 2015 No, I am using a copam but like others have said in other posts, I have another blade holder with a 60 degree blade all set up. All I do is change the holder and set pressure to 300 and all is good. I keep the speed the same but I dont have it set all that fast to begin with. Donn Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted April 16, 2015 One thing I have learned always have a second blade holder with the 60 degree blade. Eazy is right I don't have any of these printers but I have success with a Cameo SIlhouette and sometimes with my MH cutter. Share this post Link to post Share on other sites
djque 246 Posted April 17, 2015 I have a graphtec but i also use my other blade holder and a 60* blade i have it to cut twice and have it out far Share this post Link to post Share on other sites
iam1ofhis 0 Posted April 17, 2015 Still no luck with the Sticky Flock. I've tried my pressure from 175-300. It's cutting but when I peel away the back, the holes are not coming off. I've even upped it to 3 cuts. BTW, my blade is fully exposed. Any ideas/suggestions? Share this post Link to post Share on other sites
KYSIGN 233 Posted April 17, 2015 Maybe you need to add some overcut. Share this post Link to post Share on other sites
