Vinil The Kid
Cutting Master 3 don't work
downoaled the New version,
Ver.2.2.881
but it doesn't work, keeps on "Synch cutter" and the work goes to hold.
I use Adobe Illustrator CC and 6 (in both cases doesn't work)
Graphtec is your tech support for Cutting master...
And you should have the cutter on GP-GL command...
which cutter - did you double check which cutter and port is selected in the software?
Welcome from the USA, Guadalajara
Erased the plug-in 3 times and installed the old one fix the problem...
Thanks!!
Too bad, the new version seems to have some nice upgrades.....I may give it a try as long as I can revert back if need be.
