VinylRevamp 93 Posted February 10, 2015 Any of you lp2 users had issues where it cuts dotted lines instead of a straight cut? This is driving me insane!! Share this post Link to post Share on other sites
slice&dice 2,450 Posted February 10, 2015 That is called 'chatter' and occurs when the carriage is not smoothly sliding across the rails (not properly seated on track), or perhaps the blade itself is being prevented from spinning freely in the bearing (remove the holder and check for vinyl debris). Share this post Link to post Share on other sites
VinylRevamp 93 Posted February 10, 2015 I removed the holder to check for debris.....nothing there. The "chatter" happened at the same spot for all of my cuts (I did 10). How would i check if its gliding smooth on the rails? This cutter is still fairly new. I got it last September. Thanks for the reply Share this post Link to post Share on other sites
jaybyrd 3,770 Posted February 10, 2015 That is cutting across the width of the cutter? If so try slowing it down a little. Share this post Link to post Share on other sites
VinylRevamp 93 Posted February 10, 2015 @jaybird - yes..i slowed it down already from 400 to 200 on my LP2 Share this post Link to post Share on other sites
