Hello guys n gals,
I hope someone could get me out of this very annoying problem.
I just bought a Graphtec Ce-6000 and im trying to do a print and cut.
But when it starts cutting it does it on a very different spot then where the image is.
I use:
Adobe illustrator CC with the Cutting master 3 plugin.
And for this using Neenah transfer paper A3 size.
I made a print layer and a cut layer with registration marks. i then print it and then send it to Cutting master 3.
But it seems it doesn't seem to find the registration marks. I think it doesn't even search for them.
But ARMS is on..
What am i dong wrong? I hope someone can tell me.
And what are the correct settings to use?
Menu >>> IF >>> Command >>> GP-GL
That should fix your problem. Also, make the registration marks as thick as possible.
Thanks for your replies.
I have seen and used that video many times tho. Its also set on GP-GL
Its just off all the time. always to the left its seems almost 10 cm and a few cm down as well.
When it starts it doesn't look for registration marks it just starts cutting.
And maybe im doing something wrong with the placement?
Any more ideas or solutions??
