101LEDs
LaserPoint II - Liyu Model Reference
This is directly from the manufacturer. I thought it might be useful to someone at sometime. 631 is 24", 801 is 31.5" 1061 is 40" and the 1261 is the 50" version.
 TC series cutting plotter features:
1. Contour Cut Function to be optional.
2. USB 2.0 interface, support hot-swappable, and is equipped with serial port to support the long-distance data transmission.
3. 64Mb super-memory achieves a long time Offline cutting, meanwhile, the data storage can be achieved even blackout.
4. New high-speed PIC remote control system, higher speed, lower noise.
5. Digital force & speed adjustable, direct and steady.
6. Humane design, allows to adjust cutting force and speed while working.
7. High-precision "steel barbed" axis, higher accuracy.
8. Auto. memory of blade force & Speed, adjustable at any time, easy to use.
9. Emergency stops & stops to return at any time to monitor the cutting quality, easy to operate.
10. Emergency stops & stops to return at any time to monitor the cutting quality, easy to operate.
11. Unique red cutting slot make it easier to operate.
12. Cutting Length: more than 10m
post-87856-0-94618200-1410383489_thumb.j
