Kbeizaei 0 Posted September 9, 2014 I've been making decals for laptops and such with 631 and I'm thinking about switching to 651. I know that it's more permanent and has a better hold but I was wondering what other peoples experience with this vinyl has been. Thanks! Share this post Link to post Share on other sites
MZ SKEETER 4,705 Posted September 9, 2014 Oracal 651 is GREAT vinyl...can be used outdoors as well as inside,, Has more years of durability, but most colors are glossy, not matte like 631 1 Share this post Link to post Share on other sites
FrznFire07 217 Posted September 9, 2014 Love IT! we use it for all kinds of things, it does have some minor shrinkage issues but it's still far better than 631. Share this post Link to post Share on other sites
Kbeizaei 0 Posted September 9, 2014 Is the shrinkage over time? Share this post Link to post Share on other sites
FrznFire07 217 Posted September 9, 2014 651 is a calendered vinyl and any calendared vinyl will shrink due to the manufacturing process. (it is stretched not cast) therefore it has somewhat of a memory and will shrink. It probably shrinks quite a bit more in my climate than it normally would. But over time usually not more than 1/16" - 1/8". also depends on what it's adhered to and how much direct sunlight it gets. Share this post Link to post Share on other sites
mb20music 760 Posted September 9, 2014 Switch to 751 2 Share this post Link to post Share on other sites
JulieMcLain 0 Posted March 12, 2020 Is the shrinkage generally worse when it's layered? Because I made a sign & layered it. Not even 5 months later it is shrinking to the point it seems puckered. I made 3 and every single one did this. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 12, 2020 39 minutes ago, JulieMcLain said: Is the shrinkage generally worse when it's layered? Because I made a sign & layered it. Not even 5 months later it is shrinking to the point it seems puckered. I made 3 and every single one did this. did you use cast vinyl like 751 or 951? calendared shrinks more 2 Share this post Link to post Share on other sites
darcshadow 1,625 Posted March 12, 2020 Layering wouldn't make it shrink more/faster but it might make it more obvious. The layers will pull on each other and cause distortions more so than a single layer. 2 Share this post Link to post Share on other sites
