galaxygraphics 26 Posted August 25, 2014 If I am wrong, please forgive me, but I believe Chromablast, and Sublimation is about the same thing, or close, isn't it? Anyway, I have two Ricoh printers, one set up for Sub, the other set up for Chromablast. They were in an office, when I went away for a while (no NOT jail!). The air conditioning was turned off, as well as the electricity. My question is, is there ANY way to clean the ink tubes out, or even replace them, or are the printers destroyed? Any help, or advise any one could offer, would be greatly appreciated! Thank you, in advance for your help, and info! BTW, the temp was generally in excess of 90 degrees, and this has lasted for more than 45 days. I would guess that probably matters! Share this post Link to post Share on other sites
jaybyrd 3,770 Posted August 25, 2014 They are 2 diiferent inks for 2 different processes but I have no clue about cleaning them. I've never heard of 1 clogging before. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 25, 2014 inks are different - chromoblast uses special paper that actually transfers material to the garment - sublimation the ink gasses and attaches to the poly substrate Share this post Link to post Share on other sites
OWJones 1,981 Posted August 25, 2014 So have you tested the printers to see if they're working? It was hard to tell from your message. I don't know anything about the Ricoh printers, except that they're expensive and not supposed to dry out and clog... Share this post Link to post Share on other sites
jeepers94 1 Posted August 25, 2014 They don't dry out IF they are left powered on! Since the power was off if he was gone for a more than 2 weeks,they will be clogged! The newest models are a little better,but do clog. You could try the cleaning kit from ebay.I think the 1/2 gallon size is about $40. It would be worth that to try to save the printers. They claim it will work with sublimation ink. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 25, 2014 when I bought my first ricoh conde had one they used for shows that was boxed 2 months in between. the took it out, fired it up and printed perfectly. now with that said i probably wasn't stored at over 90 degrees Share this post Link to post Share on other sites
galaxygraphics 26 Posted August 25, 2014 Sorry, I fooled around and got busy!!! I do understand the difference between the two inks, in my opening statement, I was referring to the placement of the post, I should have been clearer! OW Jones, I tried to get the printer to clean, but since the ink was dried up, it wouldn't do anything! 'Magine that! I was hoping to maybe do something to perhaps ensure it worked, before opening that high dollar ink! But, oh well, here goes $275.00 or so, in ink!! Hope for the best, but expect the worse! Thanks everyone for the input! Have a wonderful week! Share this post Link to post Share on other sites
OWJones 1,981 Posted August 26, 2014 Sorry, I fooled around and got busy!!! I do understand the difference between the two inks, in my opening statement, I was referring to the placement of the post, I should have been clearer!OW Jones, I tried to get the printer to clean, but since the ink was dried up, it wouldn't do anything! 'Magine that! I was hoping to maybe do something to perhaps ensure it worked, before opening that high dollar ink! But, oh well, here goes $275.00 or so, in ink!! Hope for the best, but expect the worse! Thanks everyone for the input! Have a wonderful week! Good luck! Share this post Link to post Share on other sites
whatyoudesign 0 Posted March 23, 2015 I have a Ricoh GX e7700N with Chromablast ink. I just received a message that my ink collector is full. It doesn't look like I can open and reuse. I have checked several sites and none of them show this as a part to purchase or to even crack open to empty and reuse. Has any one else run across this and if so what did you do? Thank you in advance. Debbie Share this post Link to post Share on other sites
mr300s 1,272 Posted March 23, 2015 I think ACP Might have them http://www.acp.com/ Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 23, 2015 I have a Ricoh GX e7700N with Chromablast ink. I just received a message that my ink collector is full. It doesn't look like I can open and reuse. I have checked several sites and none of them show this as a part to purchase or to even crack open to empty and reuse. Has any one else run across this and if so what did you do? Thank you in advance. Debbie actually on the gx7000 I have opened the ink collection tank and removed the saturated sponge material - replaced it with other white abosorbant material (thinks to my daughters) as the sensor looks for that white to show it isn't full - then reassembled and kept going after resetting the message using a youtube instructions. 1 Share this post Link to post Share on other sites
mr300s 1,272 Posted March 23, 2015 I already have a spare waiting to replace not worth my time and effort and my luck I would be wearing most of it. I'll let my customers buy it for me... 1 Share this post Link to post Share on other sites
