Kelly54487 2 Posted February 15, 2014 I've imported files a thousand times from inkscape into SB. Why when I go into SB to import it, nothing is there? I've tried postscript interpreter and post script scanner and it's like my file is blank nothing there? I tried other files and they work? Any help would be appreciated here. I've included the file if someone else could try it in SB and see if it works for you? Thanks In Advance! Share this post Link to post Share on other sites
slice&dice 2,450 Posted February 15, 2014 Not sure I understand what you are attempting here. You offer a .jpg (pixel) file, not a cutting .eps vector (path) file. Open this image file within Inkscape, use the "Trace bitmap" method, and then just copy-paste the resulting vector graphic into SBE. Share this post Link to post Share on other sites
JJennings 4 Posted February 16, 2014 I am having the same problem but I am Exporting my image from Corel Draw 12.. and then try Importing it into SignBlazer but nothing is there.... I also need some help with this problem.. Share this post Link to post Share on other sites
