tammy h 6 Posted January 26, 2014 While I am cutting, the blade will grab the edge of the vinyl on either a side or the front edge and curl it under causing it to wrinkle up etc. I'm not sure why it won't cut close to the edge- is that normal? Should I be only trying to cut further away from the edge? My issue is that when my roll is off say 1/8" over the length of the cut - sometimes it gets really close to the edge. I am leaving 1/4" around the edges approx. vs. the size of the roll. I thought that would be enough but maybe it's not... Is there a specific setting that would be causing this? Should I try to adjust my rollers and how do I do that? Tammy Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 26, 2014 Why so tight to the edges? Leave more margin, the vinyl is cheap, don't worry about feeding it out an inch or two. 2 Share this post Link to post Share on other sites
tammy h 6 Posted January 30, 2014 I just thought maybe I was doing something wrong or had a setting off. If that's the standard practice- I'm good with that. I've noticed it happens a lot more on heat transfer type- I assume because it's thinner and more slick. I usually have an ok margin on the side when I get the 20" but when I get 15" sometimes I run close. It's doing it on the sides and the front line peridically. Tammy Share this post Link to post Share on other sites
