nava2642 0 Posted August 31, 2013 Hello, Does anyone out there know how to slant text like this on SCAL. Have tried a few different things, no luck. Please post if you do. Thank you for your help!!!slant example.bmpslant example.bmp Share this post Link to post Share on other sites
LPWash 75 Posted August 31, 2013 Click on the text. Then click on the rotate button. Make sure your properties toolbox is completely open. In other words, it's sort of hidden at the bottom of the properties section. I will often click the ''appearance tab" so it shrinks upwards, that way you have more room at the bottom to ''drag'' the bottom of the text section so you can see the more available text options. Hope that makes sense. 1 Share this post Link to post Share on other sites
LPWash 75 Posted August 31, 2013 Once you rotate the text. Then turn the text to the desired angle. Then skew until the letters line up. 1 Share this post Link to post Share on other sites
nava2642 0 Posted August 31, 2013 Awesome, thanks for your help, knew it was something simple. Thanks!!! Share this post Link to post Share on other sites
