koletsb 9 Posted July 12, 2013 I have a client that needs an 8'x4' banner printed and he sent me a file that is .psb because it was made in actual 8x4 dimmensions. I can't convert it to a pdf and its to large to open in illustrator so what do I do? I normally go the route of 4over but I cant seem to find a way around this. Thank you! Share this post Link to post Share on other sites
tekcorps 50 Posted July 12, 2013 Odd. Should be able to open it in AI. Share this post Link to post Share on other sites
bradsc1954 7 Posted July 12, 2013 A .psb is what you get when you edit a smart object in Photoshop. Share this post Link to post Share on other sites
koletsb 9 Posted July 15, 2013 A .psb is what you get when you edit a smart object in Photoshop. a psb is also for a very large photoshop file Share this post Link to post Share on other sites
koletsb 9 Posted July 15, 2013 If anyone is able to print from a .psb file, I will gladly just use you for the banner then. Share this post Link to post Share on other sites
darcshadow 1,625 Posted July 15, 2013 Why not just ask him to send you the file again in a format you can use? Share this post Link to post Share on other sites
tekcorps 50 Posted July 15, 2013 Can't you open the file in PS and convert the smart objects and then save file as psd or pdf? Share this post Link to post Share on other sites
koletsb 9 Posted July 15, 2013 Why not just ask him to send you the file again in a format you can use? He doesn't have any vector programs so he would end up going to someone else. Can't you open the file in PS and convert the smart objects and then save file as psd or pdf? I have not tried this, I will look into it and see if its possible. Thank you for the suggestion Share this post Link to post Share on other sites
Friedrich07 16 Posted July 20, 2013 If you're still trying to figure this out contact me I can prolly help convert the file or just print it for you. Pm me Share this post Link to post Share on other sites
