ekhatch 0 Posted January 21, 2013 Hello everyone. This is my first topic posted. I am posting this to see if I might get some advice on how adjust my machine. I use Oracal 651 material and I am having problems with almost every cut. No matter what I do I cant seem to get the machine to cut objects, letters, etc 100% for example, it will cut designs fine but when I begin to weed i start to see that at certain corners of letters or shapes, it will not have cut a smidge. So it the letters will try to lift since it has a corner that hasnt been completely cut. This is extraordinaly frustrating. I have Sign Blazer trial and the blade off set is set to .25mm I have tried tightening the blade belt and still no luck. Share this post Link to post Share on other sites
slice&dice 2,471 Posted January 21, 2013 Try using the RedSail RS360C driver. Share this post Link to post Share on other sites
ekhatch 0 Posted January 21, 2013 Try using the RedSail RS360C driver. Where can I find this? I just googled and came up empty. Share this post Link to post Share on other sites
slice&dice 2,471 Posted January 22, 2013 If you have the SignBlazer UK (all cutter) version, the RedSail driver is within the Cutter Setup screen. http://www.mystat.com/Signblazer.zip Share this post Link to post Share on other sites
bigmax 166 Posted January 26, 2013 It sounds like the blade offset may be the problem. Share this post Link to post Share on other sites
Dakotagrafx 7,299 Posted January 26, 2013 if it is cutting fine changing the offset will cause your corners to be off - with flexi it has an overcut feature that allows it to cut beyond the end of the cut and start over just a little to make sure all the shape is cut - don't remember that being a feature on signblazer adn was always a problem on the cheaper cutters 1 Share this post Link to post Share on other sites
alikat1109 0 Posted February 27, 2013 (edited) Hello everyone. Thanks for taking your time to read this. I'm using Signblazer Pcut 360. I'm trying to cut out a phone #, and no matter how big or little I cut it, its not connect from the begining to end. I have changed the offset, from anywhere from .00-.55. Could there be anything else I'm missing? I also have changed the cutting spead from 60 to 20. Still nothing has changed. The same spots everytime it cut it. Allison I did see someone say to tighten the belt. I did that and it made it better, but still not closing the cuts. PLEASE HELP. I have been using this cutter for about 2 years, and this is the first time I have come across this. I have change the blade. Edited February 28, 2013 by alikat1109 Share this post Link to post Share on other sites
