billy80808
Refine MH721 cuts unstraight rippled and wavy lines
can i ask what cut speed and pressure you guys are running?
There is nothing set in stone for pressure(force) every machine is different, even the same models.. Your pressure depends on how you set your blade,  You must set it correctly first, then that determines the force, you use for different vinyls.
Start slow on speed and learn your machine..
For me it's usually a speed issue followed by a dull blade. I chased this problem for several days once with a new clean cut blade just to realize I had broke the tip off the new blade messing around. That particular incident had me convinced my Graphtec was dead until I finally inspected the new blade.
