Coeus Clothing 0 Posted April 25, 2012 Hello , I am very new to the Vinyl Cutting world. I have just purchased a Graphtec CE5000-60 and have a Mac OSX version 10.7.3 and I am running CM2 (Cut masters 2) on CS5 (adobe illustrator 5) I have been able to load files into the the CM2 plugin on CS5 but when i send the job it will say "holding" and then the machine sounds like its going to start up but then the status light just starts to blink and never cuts anything. What am i doing wrong? I still have not figured out how to cut at all. I have pushed the test cut button and it works just fine PLEASE HELP Kolby Share this post Link to post Share on other sites
vinylmotivations 143 Posted April 25, 2012 I would uninstall CM2 and reinstall. Should fix any issues, could be that the program thinks that the hold in list checkbox is checked. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 25, 2012 Do you have your cutter set up on language mode GP-GL? You need to, if using Cutting Master2 Share this post Link to post Share on other sites
vinylmotivations 143 Posted April 25, 2012 My CE5000 when setup for HPGL will still start and just cut jibberish.... or give me an error on the cutter, what does your FC7000 do skeeter? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 25, 2012 My CE5000 when setup for HPGL will still start and just cut jibberish.... or give me an error on the cutter, what does your FC7000 do skeeter? don't know, never tried it on GP-GL Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 25, 2012 try the cutter without all those copies first. Cut a single design and get the cutter running. Share this post Link to post Share on other sites
Ballistic 28 Posted April 28, 2012 Coeus Clothing any luck? Share this post Link to post Share on other sites
z28kid 0 Posted May 4, 2012 I too would like to know as I just bought one.. As they said it would work on mac (10.7.x) and CS5 Share this post Link to post Share on other sites
vinylmotivations 143 Posted May 4, 2012 I too would like to know as I just bought one.. As they said it would work on mac (10.7.x) and CS5 Don't have any worries- this is not a typical situation and sounds like software settings... Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 4, 2012 I too would like to know as I just bought one.. As they said it would work on mac (10.7.x) and CS5 possibly if you explained more of what your problem is, somebody can help Share this post Link to post Share on other sites
mopar691 281 Posted May 4, 2012 Just for the record, illustrator CS5 is illustrator 15, not 5. Is your AI a legit copy? Pirated copies can run into these types of problems. Have you contacted Graphtec at all to help with the initial instillation? Share this post Link to post Share on other sites
