stagdriver
CT360 USB issue / Signblazer
Hi ti all, i am new herae but have read through many threads. I dont seem to have found what i am looking for and i hope someone can push me in the right direction.
I brought a 2006 model CT630 as a fixer upper.
Everything works from the panel (self test etc)
but no comms, if i plugged in the usb i get error message from xp saying device not recognised.
I removed and tested the USB connector and found one of the copper tracks on the small PCB to be open circuit.
I have placed a small wire to bridge this gap and i now seem to get comms
I have made tge reccomended settings as per the Signblazer manual and all looks pretty good.
However, if a draw a simple circle, then after selecting the correct cutter and port (usb com2, 9600 etc as per spec), then pressing cut, i get no movement if i test the system by selecting move to , origin, maximum position.
If i ignore this and go ahead to cut i get a bar graph showing the file is dowloading, but it gets only about 1/3 accross and it the whole dialogue dissapears.
If anyone is familiar with Signblazer on this model of plotter, what does your bar graph do before dissapearing, and am i being a dunce by not doing something else properly first. (Before i look further for other problems, i may try soldering the cable directly to the interface cable to eliminate the socket and pcb completely tomorrow.
i have already tried different comm speeds from 1200 bauds to 19200 all with exactly the same results.
Thanks for your help in advance
