airhead101
Vinyl Printing
is the Canon imagePROGRAF iPF6100 large format printer good for printing vinyl decals and i would also look in to getting a uscutter vinyl cutter or a roland cutter to cut the decals
You will be severely limited on vinyls you can use, That is a aqueous based printer which means the materials you can use require a special coating. Also outdoor durability and longevity will be shorter than an outdoor type printer.
You should look for a solvent, latex, True UV, or SepiaX printer for both indoor/outdoor use and more material options.
