Booper 2 Posted May 1, 2010 First attempt tonight to use the contour cutting feature with the roland and cut studio, I followed the directions and watched the youtube videos on how to do it, and I got as far as printing the decal with the registration points, drew the outline path for the cutter to use and sent the job to the cutter. It fires up the lazer, finds all three points and then just stops. No error messages no nothing, everything is exactly like how its supposed to be except the actual cutting part. Help??? Share this post Link to post Share on other sites
Booper 2 Posted May 2, 2010 Got it figured out, for some reason the cutter was set with the x & Y axis switched, put it back to factory default and away she goes!!!!!!!! 1 Share this post Link to post Share on other sites
NukleoN 34 Posted July 3, 2016 Got it figured out, for some reason the cutter was set with the x & Y axis switched, put it back to factory default and away she goes!!!!!!!! Cool! Thank you for posting the fix. I just got a GS-24 myself and plan to contour-cut soon. Share this post Link to post Share on other sites
