cegglestn 0 Posted December 1, 2007 Does anyone have there own secret recipe thats similar to rapid tac2? Has anyone tried alchohol, soap, water? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 1, 2007 alcohol,soap and water is all that I use and I go through a gallon every two weeks. I trierd a bottle of rapid Tac and other than smelling better,couldn't see a difference. When I bought the rapid tac,the guy at the sign supply place told me I was wasting my money,that the recipe I use now is just as good. I wanted to see for myself,and I did. I haven't wasted any money since. Share this post Link to post Share on other sites
dgreenh 9 Posted December 1, 2007 So you gonna give us your recipe for a gallon? I hate wasting money too! Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 1, 2007 One Gallon: Fill gallon jug about 7/8 full. add 3 or 4 good squirts of sihwashing liquid soap. I use all kinds of brands,no one seems to be any better than the other. Add alcohol to fill rest of gallon. If you want it to smell like the expensive store-bought stuff,add some vanilla falvor. Alternate,that I have used if you don't mind it being BLUE: (I got this from a sign guy with 40 years in the business) 3/4 gallon water,1/4 gallon windshield wiper solution. And the soap. There are those who will say its not as good as the store bought stuff but I do amywhere from 2 to 5 signs and banners a DAY,every day,and mostly wet. I have NEVER had a proble with it. I am usually able to remove the tape after 2 minutes or less on glossy surfaces, about 5 minutes on banners that are not glossy. Never a bubble,never a wrinkle. And I can tell you taht from having to REMOVE a few letters here and there(people do chaneg their minds)...the stuff does NOT affect the bond of the vinyl to the substrate. Let me say one thing..I have a background in chemistry and there is NO magic ingredient in Rapid Tac or any other that makes it special. They like to say there is. But there isn't. Share this post Link to post Share on other sites
jayben03 0 Posted December 1, 2007 Thanks Banner John we all can save some money with what you have just posted! Well at least I know that I can. :you rock: Share this post Link to post Share on other sites
Kimon 1 Posted December 1, 2007 When I mix my moonshine application fluid I do it by the quart - 4 drops dishsoap (less is better than more) 1/2 cup isopropal alcohol 3 1/2 cups water use a fine mister spay bottle for the bast results. Then paypal Poor Roger from Rapid Tac a couple of bucks so he can continue to enjoy his retirement. Personally I preffer dry ap/ it takes a bit of practice but I go dry 90% of the time, the other 10 percent I use my own moonshine but most liquids that are not solvent based will work ok in a pinch. Some day I will tell the story of how fierce lime gatoraid saved the day! Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 1, 2007 I can do dry on small jobs with no problem. But there's just me here and my arms won't spread 6 feet apart. I just never saw a reason for doing dry when wet does the job with less effort and less chance of bubbles or mistakes. I can climb a mountain (or could,back in the day) without safety ropes,but why would I? I've gotten into the habit of looking at vehicle graphics and wraps when I see them in parking lots and I can tell every one whether it was done wet or dry. Even one bubble is too much for me. I was behind a phone company truck the other day that had a full rear window done and ot was pieced,and one section was off by just about 1/4 of an inch. But it was enough to make it look really bad. I would bet it was done dry,or by someone who just didn't care. If doing it wet is not very professional,so be it. I'd rather it LOOK professional in the end. Thats what people pay me for. So my advice to the newbees and others is..do it wet. You have much more to lose by doing it dry. Share this post Link to post Share on other sites
Kimon 1 Posted December 1, 2007 Wet and dry age old debate, it has little to do with profesional and more to do with technigue and personal prefference. Weather conditions and temperature also play a key roll in "professional" results. Do what works for you. Share this post Link to post Share on other sites
dgreenh 9 Posted December 3, 2007 Thanks for the recipes! I always apply wet unless it it a very small decal. Wet is much more forgiving and I need any edge I can get. I've been using Rapidtac but I have to order it since there is no local supplier so homebrew would be much more convienent as well as a money saver. Can you define a squirt? I've always heard drops of soap when talking about homebrew stuff. Several squirts could be a whole bottle depending on your grip. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 3, 2007 well,about a teaspoon per gallon would be a better way to describe it. But,play around and see what works best for you. Share this post Link to post Share on other sites
luckytots 0 Posted December 4, 2007 I have not tried this, but from other forums, I was told to watch out for "new" dishwashing detergents as they contain extra chemicals that could degrade the vinyl. Stick to the plain stuff. Also, the alcohol was a no-no, but I do not remember why. Share this post Link to post Share on other sites
stormy 5 Posted December 4, 2007 Alcohol isnt a no-no. It's an excellent cleaner, it doesn't eat up the adhesive. They've used it in the leading app fluids for quite some time now. You are right about the chemicals degrading the vinyl, however. Many chemicals in cleaners such as 409, windex, etc. can eat up the adhesive on the vinyl causing the vinyl to have a shorter life and can cause premature fading. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 4, 2007 on the alcohol...DENATURED alcohol is the one that is a NO NO!!!!! regular rubbing alcohol is what you use. I use denatured to remove adhesive residue,so I'm sure uts not good for the adhesive on the vinyl. Share this post Link to post Share on other sites
bowhunter012004 4 Posted February 13, 2009 thanks for saving me money Share this post Link to post Share on other sites
BannerJohn 1,324 Posted February 13, 2009 since this thread has been re-opened, I think I'll give an update. About a month ago I bought some RapidTacII just to see if it was any better. I did tests...same vinyl,same cut,same substrate. The results...I could not see that RapidTac did any better than my recipe...in fact on coroplast,it didn't do as well. Conclusion...I paid $8 for a quart of something that smells better than what I make myself. Share this post Link to post Share on other sites
cegglestn 0 Posted February 14, 2009 When I mix my moonshine application fluid I do it by the quart - 4 drops dishsoap (less is better than more) 1/2 cup isopropal alcohol 3 1/2 cups water use a fine mister spay bottle for the bast results. Then paypal Poor Roger from Rapid Tac a couple of bucks so he can continue to enjoy his retirement. Personally I preffer dry ap/ it takes a bit of practice but I go dry 90% of the time, the other 10 percent I use my own moonshine but most liquids that are not solvent based will work ok in a pinch. Some day I will tell the story of how fierce lime gatoraid saved the day! Ive tried this recipe and works great, I added a bit more isopropyl (mint rubbing) alcohol and some vanilla extract and its amazing at 10-30 degree temprature, no problems yet with around a 2 min wait Share this post Link to post Share on other sites
Booper 2 Posted October 24, 2009 Just tried the homebrew a few times on a window and no matter how much I squeegie or how long I leave it on there the decal will NOT stick to the window. Some help please as Im supposed to be installing bedstripes on a pickup truck later on today. Ben Share this post Link to post Share on other sites
MikeMan 0 Posted October 25, 2009 Just tried the homebrew a few times on a window and no matter how much I squeegie or how long I leave it on there the decal will NOT stick to the window. Some help please as Im supposed to be installing bedstripes on a pickup truck later on today. Ben You're not using clear app tape are you? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 25, 2009 Just tried the homebrew a few times on a window and no matter how much I squeegie or how long I leave it on there the decal will NOT stick to the window. Some help please as Im supposed to be installing bedstripes on a pickup truck later on today. Ben did you clean the window real good? like with alcohol? What type/kind of vinyl? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 25, 2009 since this thread has been re-opened, I think I'll give an update. About a month ago I bought some RapidTacII just to see if it was any better. I did tests...same vinyl,same cut,same substrate. The results...I could not see that RapidTac did any better than my recipe...in fact on coroplast,it didn't do as well. Conclusion...I paid $8 for a quart of something that smells better than what I make myself. I can attest to Johns recipe working better than rapid tac with 751 on my truck! Share this post Link to post Share on other sites
Booper 2 Posted October 25, 2009 Nope, its paper tape, Oracal 651 and I cleaned the glass with the same solution, wiped it down with paper towel, did it again, sprayed the glass, sprayed the decal, applied it, squeegied the everloving @$^@ out of it until I couldn't see any more liquid coming out, let it sit for a half hour, squeegied it again, sprayed the app tape to release it and the whole decal comes off. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 25, 2009 I pull the tape after 2-3 minutes. Never any problems/ On a vertical surface, I don't spray the tape..the spray wants to go back under the decal. But after 30 minutes, I guess the tape had dried to the point you had to spray it. Share this post Link to post Share on other sites
Booper 2 Posted October 25, 2009 Only thing I can think of is I bought the alcohol from the dollar store and it says on the bottle 50% alcohol solution but the ingredients are just alcohol and water. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 25, 2009 that's about right. You can buy 90% but usually at drug stores only and more expensive. That's what we used to clean tape heads years ago. Share this post Link to post Share on other sites
Booper 2 Posted October 25, 2009 Would using an empty Fantastic spray bottle that I rinsed out mess it up? Share this post Link to post Share on other sites
