select7 0 Posted December 8, 2009 http://img192.imageshack.us/img192/2592/ddlogo.jpg I need help vectorizing this logo. Dont know why the AI file I have is being weird. Can anyone help please?? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 8, 2009 nothing there but a tiny little square with an x in it Share this post Link to post Share on other sites
select7 0 Posted December 8, 2009 Really? The link works for me. Let me try reposting it. Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 He ya go, you'll have to do some cleanup w/ illy. it's a PDF just place it ddlogo.pdf ddlogo.pdf Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 Let me know if this is good for you Share this post Link to post Share on other sites
select7 0 Posted December 8, 2009 Thanks but I am still a newbie. I have no idea how to do that.. Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 Right click the PDF and chose "open with", then chose illustrator. Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 Here is the AI. ddlogo.ai ddlogo.ai Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 That ai is ready to cut Share this post Link to post Share on other sites
select7 0 Posted December 8, 2009 Hey Signgame, thanks for all your help. So I saved the .ai file and put it into my sbd folder. Am I supposed to open it in AI first, then convert to an .eps? Thanks again!! Share this post Link to post Share on other sites
select7 0 Posted December 8, 2009 Because when I do the .eps conversion in AI, it wont open in SignBlazer. I have CS3 if that matters. Someone told me that it needs to be a version 8 or older? Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 Save the ai as Version 8 and then drop and drag from the desktop into sign blazer, if that won't work copy the image in illustrator and paste it into signblazer. I use sign blazer at home, have had the same issue. Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 Call me in the next 15 at 561-392-8626, ASK FOR JOEL B. Share this post Link to post Share on other sites
SignGame 0 Posted December 8, 2009 I suggest looking into getting Flexi Pro, so much more fluent w/ illy files. There's alot of tricks you can use in your version of illy. I'm using CS2 and was able to trace that w/ no problem. Next time place your JPG into a new illustrator drawing, then go to OBJECT. Under object you'll have a LIVE TRACE option, go to that, on the menu that pops out go to TRACING OPTIONS and play around a little, once you get the hang of it you'll be vectorizing in no time. No biggie Share this post Link to post Share on other sites
select7 0 Posted December 8, 2009 Thanks again Joel! Share this post Link to post Share on other sites
