veddderman123 0 Posted August 11, 2009 I've got a cop friend who needs some work done on some squad cars but I've never cut reflective vinyl before. Anyone who has done this before please give me some tips... Also what kind of vinyl would I be best for the job? Share this post Link to post Share on other sites
kart45 6 Posted August 11, 2009 Cutting is the same in my experience with racecar numbers, just lower cutting depth/higher blade pressure on thicker material. It also seems to have a tendancy to rip/tear a little easier on sharp cut angles. I've only used Avery and 3M reflectives; 3M was easier to work with but it had some sort of patterned backing on it that gave it a slight texture, Avery was smooth but required a little extra att'n prepping and applying. Share this post Link to post Share on other sites
jfought 120 Posted August 12, 2009 Cutting is the same in my experience with racecar numbers, just lower cutting depth/higher blade pressure on thicker material. It also seems to have a tendancy to rip/tear a little easier on sharp cut angles. I've only used Avery and 3M reflectives; 3M was easier to work with but it had some sort of patterned backing on it that gave it a slight texture, Avery was smooth but required a little extra att'n prepping and applying. what was said here is great. cut it slow and use a new blade. Share this post Link to post Share on other sites
JoeDirt 5 Posted August 12, 2009 maybe a 60 degree too! Share this post Link to post Share on other sites
jfought 120 Posted August 12, 2009 No sharp points... so true Share this post Link to post Share on other sites
