Karl
USB Keyspan and serial = this helps
Am using older Mac G450 with a NEC usb card & the PCUT630 USB  & FlexiCut8 Starter
The card is compliant with both the mac and cutter --the chip set is important, as described in other posts here.
the biggest problem is getting drivers that are "conversive" enough to communicate with both Mac and Dos (pc)
I did try several USB / pci cards and several drivers, but NO comprenda. I also tried different serial to usb cables.
Most of that action was with another -very old- cutter. When I got this PC630 with the usb connection, I thought that it would be simple enough to set up, however.. the Flexi would not recognize any usb connections.
I was about to purchase a Keyspan serial to USB device, and thought to download the software first.
Keyspan USA-19HS  aka  keyspanusadrvr
-- there are several drivers for macosx, if one doesnt work, try another. if that doesnt work, buy the hardware.
once rebooted, the cutter showed up in the Flexi setup and cut as expected.
I found the 19-HS for less than $30 at Amazon, in retrospect, it would have been cheaper to get the Keyspan first, but then I wouldn't have all these extra parts on hand   :police:
Update:  the built in usb is 1,  and by definition sloow. The result has been that anything over 10 letters results in serious problems: lines cut across the copy, partial cut letters, locked up cutter, and more.
I have made a series of adjustments to the Flexistarter software settings and so on, but still the problem persists.
All comments and input suggests that the data is not being handled quickly enough. The Keyspan is a USB 2 device,  by-passing the cutter's usb, using the serial connection plus the keyspan usb2 will at the very least double though-put, so I have ordered one, Until it gets here, I will have to continue cutting ONE WORD at a time.
SO; :lol:
Question for USCutter: why not put USB 2 built in? why bother with usb 1 since it is too slow to transfer data?
Or, Include Keyspan as an optional accessory for the Mac.
Installed Keyspan USB 2.0,
problem gone
Highly recommend to All Mac users, GET the Keyspan before you bother to cut at all.
for $30 it will save you that much in wasted vinyl.
:thumbsup:
So after hours of heartache and trashed vinyl, I finally consulted with US cutter on an issue of my 721 stopping in the middle of a job.  It kept throwing a communication failure error.
I'm using a MacBook Pro OSX 10.5.8, Illustrator, Signcut X2 and a MH 721 cutter.  I was using this via USB.  DON'T DO THIS!!!
US Cutter said to purchase a Keyspan USB to serial device.  I couldn't find that brand specifically, so I bought an I/O Gear USB to Serial.  Worked perfectly!
DO NOT BUY A BELKIN CONVERTER!  The box says that it is Mac compatible, but it does not support OSX.  I tried to install it, but it is written in Classic OS, not OSX.  I was lucky that Staples took it back.
All good now...
I'm confused. The Keyspan has posts on the male connector and my LP24 serial port has posts on the serial port (female). These two items won't fit together because both posts will keep them from coming together,  and nothing screws into the other.
How do you guys make the keyspans fit the cutter if both items have posts on them?
Is the USB2 really necessary for serial, or can I use a simply DB9-USB adaptor with actual screws that can screw into the posts that are on the LP24? Without a screw-in fit the connection won't be possible (or secure).
Is there some kind of adaptor you're all using with the keyspans to make them fit a female serial port which has posts on it?
I'm not sure if I understand the "posts" but this is how it works. A keyspan is a serial (on the LP side) to USB (on the computer) converter. You shouldn't need any other adapters to use the keyspan. It's just simply gives you the option to connect your USB cord to the serial port of the LP. The keyspan is the adapter.
Not sure about your particular plotter but some users need to connect the provided serial cable, then the keyspan then the usb cord to your computer.
Exactly
in fact the plotter comes with a serial cable, just plug that into the cutter - keyspan into the serial - keyspan usb into the computer.
And as Kimon said in another post, it is not the through put aka usb2 vrs usb1, but the "clean data" required by Mac pc system, that msdos pc systems can tolerate.
I have a G5 Quad 2.5ghz with a keyspan and a graphtec 2100-60 cuttter and I put some letters in the window of the Flexi 8.5 and click on Send and in the production manager it says that it is cutting - shows a percentage and then disappears -flexi has sent the data. (we did choose the right cutter in setup) (I tried 2 different usb cables as well connecting to the Keyspan.)
Problem is: The cutter sits there and does nothing. We think it is sending data - but something must be failing. Any ideas?
Update: CHecked with Keyspan - it is working properly. Checked with Flexi - software is working properly. Checked with Graphtec and they say a regular cable from the keyspan to the Graphtec will not work - have to buy theirs. I will buy it and see if it works.
So I just got the Keyspan serial connector as recommended by Mac users here. I installed the drivers, but most have some setting wrong since the cutter is still not working.
When I go to Networks in System Preferences the Keyspan is there (2 ports are showing up, KeySerial1 and USA19H64P1.1) I've tried both with no luck. Both say not connected in Networks, I click connect, nothing happens, except once the cutter started to move, rollers moved one inch at a time for about 45 seconds, then nothing. Still said not connected afterwards.
Pretty sure settings are just not correct, but can't find the correct settings anywhere to compare them with.
I am using SignCut Pro.
Thanks.
I gave up on the graphtec and bought the Pcut CT-630. I use a Keyspan with mine and after tech advisor at US Cutter explained to me that I need to select the profile for the cutter with my Flexistarter then after the cutter profile is selected you might have to restart the cutter (which I had to) and it worked.
I just wanted to let others know, I purchased a LaserPoint II with the goal to initially hook it up to my Windows computer to get the signs I needed for my business made and then when I had more time, to work out the bugs to make it work with my Mac.
Since my Windows computer did not have a serial port, I had to order one for it.  I also ordered a Keyspan with the headerport.
It delayed my sign making almost a week, and when I got it finished, I decided to try to see if it would work with my Mac.
Well, you don't need the Keyspan with the LaserPoint II.  All you need is a USB cable and it works fine.  I would have been done a week earlier if I just hooked it up to my Mac.
Great,  report back in 3-4 months after cutting more, and tell us how it is still working on USB...  If you get the opportunity,cut some large decals 6-8ft..or some really detailed designs. Hope it holds out for you...
