Brandiland
Members
  • Content Count
    18
  • Joined
  • Last visited
Posts posted by Brandiland
  1. I saw the link above for the parchment paper. Can someone chime in, who has used it? I was wondering if the transfer tape sticks well enough to it,to ship. I'm currently cutting decals, and the client would also like the inside portion of the design, that I would normally weed out and throw away.
    Or, If anyone happens to know where to purchase the same mil wax backing,that would be helpful too.
  2. <blockquote class='ipsBlockquote'data-author="Mz SKEETER" data-cid="412830" data-time="1455299864"><p>
    Are you putting the laser correctly inside the first registration mark, lower right> then setting Origin, then Click OK to cut.? If your doing all of that, then contact your support..techs. Signcut or Saga.</p></blockquote>
    Yep, did all of that. I emailed support yesterday. Hopefully, I'll hear something soon. I'm not sure how to add a picture, or I'd show you what it looks like.
  3. Alright, so I've dug around on here for a while. I can't seem to find what I'm looking for, but I've seen quite a few intelligent people, so I figured I'd start here.
    I'm using Signcut Pro with ARMS on a Saga 2400 cutter. I've read the instructions they give on how to align my registration marks. I even made my own registration marks at 25mm long in each direction (as suggested). I'm not sure my cutter is trying to see those marks. It's not consistent in its errors, making it very difficult to find the problem. Sometimes, when I click "ok" to cut, nothing happens. Sometimes, it trails off to the left and up as if it's looking for the registration marks, but then stops short, and begins the cut, or draw,in my case. I feel like I'm missing something.
    Can someone who uses the ARMS system with Signcut Pro help me?
  4. I set the blade depth by taking it out of the holder, and cutting a circle on vinyl. The circle cuts through the vinyl, but just barely leaves a mark on the wax paper underneath. I place it back in the machine, and adjust pressure accordingly. I had a machine before this one, that cut fine.
    How do I add to the over cut? I'm not sure I understand that statement. Also, this test cut is from the machine, not the software, if that makes a difference.
  5. I spoke with someone from US Cutter. They told me my warranty is voided if I have to send the unit back, because I no longer have the box (box was damaged in shipping). So they are sending a motherboard when they get their next shipment of them, in about a month. I'm dead in the water until then. Even then, that may not be the problem, resulting in a longer wait, or worse..a dead machine.
    I'm a little frustrated about the box ordeal. I see on the site where you can be reliable for damages if not packed correctly, and it's damaged, but to not even get to send it back at all, just seems a bit much. I package electronics all the time. I'm well aware of the grade of box this machine requires.
  6. Hi,I've searched the site, and can't find what I'm looking for. Please forgive me if this has already been mentioned.
    I have a Titan 2 refurb. I've been using it for about 9 months with no issues. Today,I turned it on and the cutting unit slung as far to the right as it could possibly go. Then, the display screen started flashing blue about every 2 seconds or so. I've turned it off and unplugged it When I turn it back on, nothing happens other than the blue flashing light.
    Please Help
  7. I'm cutting a wheel decal that will fit inside the rim of a motorcycle.I know I'll need to allow for the curve, when calculating my measurements, but I'm a little unsure where to start.The rim is 17". I made this one that's attached, but it's straight. I'd like my clients to not have to work so hard to get the perfect fit. Any help would be greatly appreciated.
    post-97016-0-50582700-1452088510_thumb.p
