All Activity
This stream auto-updates
- Today
Potent Stream Reviews ™ | Risky Prostate Supplement | Only $49/per bottle! Check Price!
hammondsheffield posted a topic in General discussion
➢ Product Name — Potent Stream ➢ Category — Dietary Supplement ➢ Availability — Official Website ➢ Main Benefits — Bladder Control Support ➢ Side Effects — N/A ➢ Rating — ★★★★✰ 4.8/5 ➢ Official Website — https://www.healthsupplement24x7.com/get-potentstream Huge Discount! Hurry up! Order Now! Huge Discount! Hurry up! Order Now! Huge Discount! Hurry up! Order Now! Potent Stream is a prostate health supplement that provides users with nine ingredients that are known for their prostate benefits and support for the urinary tract. The formula is available as a liquid, which works quickly to improve inflammation and restore the user’s sex life. PotentStream is designed to address prostate health by targeting the toxic, hard water minerals that can create a dangerous buildup inside your urinary system. This potent formula has been expertly crafted to target and tackle the fundamental root cause of prostate issues in men. By doing so, it can enhance the overall functionality of the prostate gland and promote better bladder control. What Is Potent Stream? PotentStream was created for men to assist them in resolving bladder problems and supporting the prostate. The product utilizes a 100% natural solution that combines several herbs and plant extracts in the optimal dosages to effectively cure and maintain your bladder, sex drive, erectile dysfunction, and sometimes infertility. The supplement’s original blend contains 14 components, three of which are crucial primary constituents that significantly increase its effectiveness or potency. According to the manufacturers, the supplement is a mixture of naturally potent ingredients that are clinically proven to address the root cause of an enlarged prostate and restricted urinary flow. Bioactive components in the formula revive the normal functions of the bladder, urinary tract, and kidneys to facilitate the effective removal of toxins and optimal prostate functions. Visit Here To Order PotentStream From Official Website To Buy With Special Offer -
hammondsheffield joined the community
propertyyeg joined the community
- Yesterday
Cedric September joined the community
- Last week
I found this in a unit we are cleaning to sell. What is it?
haumana replied to fatmike's topic in General discussion
I'm guessing it's a 24" machine. Definitely worth turning on and seeing if it works. -
slice&dice replied to fatmike's topic in General discussion
Are you intending to begin utilizing this cutter for your own purposes? Or, are you just looking to sell (storage Unit auction, this was in the room?) What width is that ? (not good pix of the machine). Do you have a laptop available to see if you can get this operating? -
MZ SKEETER replied to fatmike's topic in General discussion
It looks to be a Saga. Or rebranded Saga, Titan would be blue and sold by UScutter. It should have a model number plate on it. UScutter sells parts for it. And has a user manual for it. People seem to like them, If they are working correctly. ..Depending on model, some have servo motors. Turn the power on it and see if it says on the screen what it is.. You can purchase Vinyl Master cutting software for it. https://uscutter.com/TITAN-2-Vinyl-Cutter-28-53-68-inch/?gad_source=1&gclid=Cj0KCQjw8pKxBhD_ARIsAPrG45mALfiNF25H4lMLXl3RJJTch7u5PWWZrcIPjRMuE3nmoay3ED8Tps0aAmcBEALw_wcB https://www.aliexpress.com/i/3256801650397084.html?gatewayAdapt=4itemAdapt -
fatmike started following I found this in a unit we are cleaning to sell. What is it?
fatmike posted a topic in General discussion
This was in a unit we are cleaning to sell. Can anyone help me I'd it and what software is used with it? Is it worth buying replacement parts for and using or should I dumpster it? Are repla ement parts available? Maybe a manual? -
The SignBlazer setup link is right HERE ----> https://www.mediafire.com/file/fjk69hgu2cpnr16/signblazer_setup.exe/file
Which cutting software are you referring to? The cutting software with an activation code is only for the original buyer. It would be registered to the Original buyer and cannot be transferred. Signblazer is free abandonware, if you can find a link for it. It is older and many still use it, your CE7000 won't be on there, but many are using an older Graphtec 50 for newer Graphtecs set ups.. Or purchase Vinyl Master. https://www.graphtecamerica.com/software You "might" be able to get software here, after you register. https://www.graphtecamerica.com/register-gs2
- Earlier
Rookie mistake. I bought a second-hand CE-7000 without knowing I would need an activation code to use the cutting software. Of course, the person I purchased from does not have the activation code. Do I have any options at this point? Any help is greatly appreciated.
Um Treiber für den GCC Jaguar II 61 Cutter zu finden, empfehle ich Ihnen, die offizielle Website des Herstellers zu besuchen. Dort sollten Sie Informationen zu Treibern, Downloads und Kaufmöglichkeiten finden können.
The issue is with Silhouette not being able to connect to CorelDraw, correct? Was there an update that occurred with your computer and/or Sihouette?
Hi, I have CorelDraw 2019 and I was doing fine until two days ago. Now it says It can't connect to CorelDraw. I've uninstalled the Silhouette Connect Software and installed it again. It worked for one time only. Now I get the same message again.
Too little information about your problem. Please provide better details, so we can properly evaluate the nature of your issue here.
what software are you using? are you sure there isn't an image that's in white and blending in with the workspace background? the cutter isn't going to cut what's not sent to it. have you tried just cutting by color? you can also post the file, and maybe someone else can see what's going on.
I seem to have a problem, when I select a image to plot, the image is shown,as the correct selection but when I proceed to plot my choice of image the cutter starts to plot a image some thing like a sunburst in straight raydiant lines , cannot move this sunburst line image . can any one help and direct me to the procedure how to move the image, it would seem the image may for some reason be stuck in the memory or something like that thank you
nrnmcevily2 started following SchroDies
I operate a 'cheapo' SC2 cutter, and the results it produces are equal to a high-cost Graphtec or Mimaki or Roland. This machine is tasked with making sign lettering, and signs come out looking great.
I guess the question to ask is what are you wanting to do with your cutter? I don't have a Titan 3 or Graphtec 7000, but I do have a LaserPoint (i), Graphtec CE6000-60 Plus, and Titan 2. Between the three cutters, I would say that the Graphtec is by far, the most accurate of the all the cutters, and even though my first generation LaserPoint is over a decade old, I feel like it's better built than the Titan 2, though the Titan 2 is much quieter. I would say, if your budget allows, get yourself the Graphtec, or if you're looking for something little easier on the budget, then perhaps a good condition Graphtec CE6000.
Have you checked the youtube videos? The cutter is a rebranded Saga vinyl cutter.. From what I have read, people seem to like the Titan 2 and 3 vinyl cutters. And they say good quality cuts. Those 2 have servo motors. It all has to do with getting a correct set up of blade depth and force, just like any other vinyl cutter. As far as speed, personally I cut slow, no need to run fast. It's not a race. We have OPs come in here and complain about new Graphtecs and we pretty much have to steer them into setting their blade depth correctly. That is the first thing that you have to get correct. It is posted on this forum hundreds of times. You do not use a credit card or post it notes to set your blade depth. That is about 10 times too much blade exposed out of the blade holder. It is a myth that just won't die. Even USCutter still puts that in their instructions, it is wrong. It looks like Titans are on sale. As always, buy the best that you can afford. https://uscutter.com/TITAN-3-Vinyl-Cutter-ARMS-28-53-68-inch/
I need some help on deciding what to get drop your opinion. I've done some research on titan 3 cutter and there's not much info out there or videos on how and what kind of cuts or quality it does? Does it get close to what a graphtec ce7000-60 plus do ?
Oh My, I seem to have referenced the O-P (gossages) who indicates Sanford Fl. USA!!! That was over 14 years ago. Rarely do I need a local sign shop to assist, but keeping good relations open is important in our field (as it should be). Just a few weeks ago, a certain job I was doing required a specific shade of Green. Didn't need much, just a smidgen. Ta-Da! The local FastSigns came through for me, they're run by a good guy.
Quite the drive to Florida. Their Facebook current page has them located in West Virginia. A poster is even thanking Sissy. Dot come page is West Virginia.
Down there in Sanford Florida, you can walk into a local Sign shop and ask for their help. Most retail signage places are implementing Flexi in their workflow.
No, you would need the Flexi software to export as a different file format. Tell your customer to contact the creator or you contact the creator and send them in a format that you can use. Most would export as an .eps. Which can be used in most softwares. You would probably not even know which version of Flexisign pro that they used. An older version of Flexisign Pro cannot open newer files, or only up to a certain version. My Flexi software (10) is older and cannot open newer Flexi files. A newer version can open current and older files. It looks like they are up to version 22 now.
Sis834 started following FlexiSign .FS file needs converting please ;-)
Hi, I recently received files for a customers car vinyl. The creator used Flexisign Pro and they are saved as .FS files. We use WinPCSign 2012 & 2018. We do not have the luxury to switch out to a new software. Is there a way to convert these .FS files over to something that I can open in WinPCSign? The photo shows what files that can be imported into WinPCSign! any direction would be appreciated!! thank you sissy@rpperformanceracing.com
Contour and perf cutting issues
MZ SKEETER replied to cyberkeith1's topic in VinylMaster CUT, LTR, PRO & DSR
Making your software work with the vinyl cutter is a Vinyl Master or UScutter job. Are you using 1 blade holder for both processes or 2 different blade holders ,blades set individually for each process? The process I have read with the Graphtecs, is to use 2 different blade holders. 1 is set for the contour cutting. I is set up with blade extended further out of the blade holder for the perf cutting. They don't change the force, maybe just a little. Blade holders/blades are preset to cut, for each option. with the blade in them. Just change the blade holder/blade, for each process. That's all I can add. There are only a handful of forum members here that answer questions. None of them have a Titan 3 vinyl cutter. Maybe some one else can add something. -
cyberkeith1 replied to cyberkeith1's topic in VinylMaster CUT, LTR, PRO & DSR
Thank you the response, yes we use a cutting mat under the sticker paper whenever doing this operation. The Titan 3 can accomplish Kiss cut, thru cut and perf cut. The Titan 3 will cut all three from 1 file. My question more relates to the software, specifically when editing the pressure of the second perf cut. The information is not changing from the first setting as in the video. So whichever pressure you set for the first cut, it maintains that pressure in all cuts for the object. You can say print 2 stickers on one page, both with 2 cuts, but handled as separate objects so 4 cuts in total. setting say the first sticker at a cut pressures of 80/160 for the cuts and the 2nd for 100/ 200 on the second sticker. The first cuts at 80/80 and the second cuts at 100/100. The second cut on each is a perf cut, but with no pressure change kind of defeats the purpose and will not cut through Yes, every other function changes the cut speed and grams just fine from software control. I do mostly vinyl cutting, but stickers are fun also. I just wanted to try the easy peel method and I must be missing something somewhere. The Titan 3 is very fast and quiet, it dose a great job and I am starting to make and post videos and sharing the information. Thank you again, Keith
