MonkeyMeMe 8 Posted November 1, 2008 Ok in Sign blazer when importing things into programby eps, to cut, does it only take eps, and if not what other graphics, does it cut from and there is a selection to be made to cut, it says Use full Post Script interpreter or Use Post Script Scanner, What is the right one to select? Thanks Share this post Link to post Share on other sites
nonabelle 5 Posted November 1, 2008 Ok in Sign blazer when importing things into programby eps, to cut, does it only take eps, and if not what other graphics, does it cut from and there is a selection to be made to cut, it says Use full Post Script interpreter or Use Post Script Scanner, What is the right one to select? Thanks u can import jpg and other file formats. u can also vector them in sb. i use the first one. which i think is ps scanner. hope this helps ya. Share this post Link to post Share on other sites
mobby 1 Posted November 3, 2008 For eps import, rules are simple. If the import preview is a black square, or unrecognisable graphic, then use interpreter. If preview is accurate representation of the graphic, then use scanner. If you use interpreter, you get more points Cheers mobby For blazer situation http://www.computerandlaser.com.au/SB_Support.htm Share this post Link to post Share on other sites
MonkeyMeMe 8 Posted November 5, 2008 ok so i can bring jpgs in sign blazer? and then turn to vector to cut,, please tell me more,, , Do i export insignblazer from jpg to eps? I gotta know this,,, please share,, thanks Monkey/ Sandy Jo Share this post Link to post Share on other sites
