n7kon 1 Posted October 28, 2008 I have a 2 color logo that is a simple oval with writing in it. My question is when making the vector file which is better practice? To layer the writing over the top of the oval, or to cut out the space for the lettering from the oval and then making the text for the spaces remove. This will be on a window and on the outside. I was thinking of cutting out the lettering space from the oval and then making the text slightly larger then the cut out and putting the lettering down and then the oval over the top. Thanks for any advice Keith Share this post Link to post Share on other sites
JoeDirt 5 Posted October 28, 2008 I would just layer it period make two cuts one oval then the text. Share this post Link to post Share on other sites
RegisG 0 Posted October 28, 2008 If the text is very small, I would weld/punch in the circle and then layer over your letter color. For very small letters, it is much easier to weed the letters as opposed to leaving the letters. Share this post Link to post Share on other sites
darkdan 3 Posted October 28, 2008 Depends on whatwho are on the other side of the window. Some people may not want to see two overlapping ovals from the backside and would prefer to have one solid color oval. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 28, 2008 Depends on whatwho are on the other side of the window. Some people may not want to see two overlapping ovals from the backside and would prefer to have one solid color oval. agreed. Either way will look good from the front,so go with whichever looks best from the back as well. Share this post Link to post Share on other sites
n7kon 1 Posted October 28, 2008 Thanks all for the help. I am going to go to the site and see if it can be seen from the inside. If so I may try to talk them into one on each side. If not then I will just layer it. Thanks Again. KeithH Share this post Link to post Share on other sites
FBRsportmod68 109 Posted October 28, 2008 what I would do, and this is just me, I would make the oval, put the text in, punch it out......it would look the same from both sides just on the inside would be reversed. Hope this makes sense. Share this post Link to post Share on other sites
