rlong
Some of my work
I don't use the plotter for traditional sign making. I use it to cut complex patterns out of styrene to make sci fi miniatures.
Here's some examples.
All the panels here were cut out of thin styrene.
width=800 height=540http://sovereignreplicas.com/k_350_063.jpg[/img]
And the finished piece, after making a mold and casting it in fiberglass. All the small surface panels were cut on the plotter from styrene.
width=750 height=600http://www.thelightworks.com/models/img/models/klingonbig_05.jpg[/img]
width=750 height=600http://www.thelightworks.com/models/img/models/klingonbig_08.jpg[/img]
Here's some more examples of what I've used the plotter to make. All of these were scratchbuilt.
http://sovereignreplicas.com/sf.htm
width=800 height=600http://sovereignreplicas.com/ac_4.jpg[/img]
Uh, that's amazing!  Can you give a little more detail on how you accomplish cutting foam with your cutter?  Got any videos to share??
Guest TracMatt
Like my son would love you!
AWESOME!  There is not much else I can say.
Tracee
WOW :huh:
Pretty amazing use of a plotter. Hats of to you for originality and awesome craftsmanship.
that is awesome and the most unique use for a cutter that I have seen so far! Maybe the folks at ILM need a cutter. Sure would cut down on the budgets for the movies they make FX for.
well beam me up Scotty!!!
that has to be the most unique item i have seen by using a cutter.. more details please.. are you just making the pattern so you can cut in the foam or ?
damn nice..
EDIT..
woah.. i just went back and more photos are now showing up.. that is just amazing.. i like the klingon warbird but the enterprise is sweet.. are u using fiber optics for the lights?
did a lil snooping.. saw your Naboo Starship and some other items.. man you do good work.. :thumbsup:
:thumbsup:
Really amazing!  Would love for you to do a simple tutorial on the process you use.  Model building is something I'd love to try with my cutter.
So maybe I'm a little slower than most, but for the life of me I can't figure out how you're doing that stuff. Pretty spectacular, and like everybody else, I"d really love a tutorial or better yet, a video, of the process.
Thanks for sharing,
Carol
Thanks for all your nice words. The plotter is used to make all the surface detail. I'll usually take a cg mesh, flatten it out, then use the plotter to cut 3 dimensional pieces, but only flat. The plotter makes short work of styrene sheets, and can do incredibly small details that are then glued on the pattern before molding.
For instance, this piece here was completely cut out of sheet plastic, then folded together.
And the finished piece.
For other applications I make complex paint mask's like these.
width=800 height=600http://sovereignreplicas.com/kkee014.jpg[/img]
So I can do paint jobs on these miniatures that I could only dream of doing by hand.
I wish they made a scribing blade for the plotters, it produces more than enough downforce to scribe into even plexiglass.
Guest TracMatt
Do you have any pictures of while your doing this?  It would be great to see some of the detailed work being cut on the cutter and so on.
Tracee
That is awesome! I am having trouble learning to cut vinyl let alone something that is so complex like you are doing. How creative you are! Thank you for sharing!
Christi
