ky1duck 0 Posted June 10, 2007 after applying lettering to a semi truck, look great then after 1.5 days there r air bubbles popping up, i put them on wet using water/soap. washed truck first aint sure of vinyl company/type. looked great when first done. now getting airbubbles. what did i do wrong. thx rob Share this post Link to post Share on other sites
BannerJohn 1,324 Posted June 10, 2007 No idea,usually it's the other way round with me.Air bubbles usually go away when the vinyl sits in the sun for a day or so. It could be that there were still pockets of moisture,and when it evaporated,left an air pocket.I"ve left a banner on my work table that looked great and an hour later,the odd bubble shows up. If the vinyl is self-healing, just prick the bubbles with a very tiny sewing needle.Do NOT be tepted to use the edge or end of an exacto knife. Maybe someone else with the same problem will lend a hand here. Share this post Link to post Share on other sites
TaterNuts 3 Posted June 12, 2007 I think that it sounds like a soap problem... What kind of soap did you use??? I always put some alchohol in mine when i make my own, try using rapid tac application fluid... Share this post Link to post Share on other sites
