dlpeace 0 Posted June 6, 2007 Please help me i cant get the artcut software to work with ploter usb com port or somethings not set right please help Share this post Link to post Share on other sites
kenimes 42 Posted June 6, 2007 ArtCut or do you mean SignCut? Share this post Link to post Share on other sites
chris4847 0 Posted June 6, 2007 The problem that I had was that I did not set the baud rate to 4800 on the plotter. after I set it, it worked great. You have to set it everytim you turn it on or reset, or at least that is the only way that I know how, someone else probably knows better. Share this post Link to post Share on other sites
TaterNuts 3 Posted June 12, 2007 pro720 is identical to the MH721.... He is probably talking about Arcut cuz the pro720 is bundled with it... Bridge is the branding label in the pro720 right? Share this post Link to post Share on other sites
kenimes 42 Posted June 13, 2007 Yep, Bridge bundles with ArtCut. Share this post Link to post Share on other sites
the falcon 0 Posted August 4, 2007 Help please. I have the bridge pro720 and it has failed to respond when I use the cut command on both SignCut-X2 and Artcut. I have followed the directions in setting it up with USB and with LPT, set the baud settings correctly and everything. The test button on the actual plotter succesfully makes a box inside another box, but still no response when commanded from the computer. Thanks -Aaron Share this post Link to post Share on other sites
kenimes 42 Posted August 4, 2007 Leave the baud rate at 9600 in SignCut. Anytime you power cycle the cutter, it defaults to 9600. Share this post Link to post Share on other sites
LockTee 0 Posted October 7, 2007 Which driver and model have you setup in Artcut? Also you mentioned that you are using a usb connection did you try your com ports? I believe the default is com3. Share this post Link to post Share on other sites
fbrgraphics 0 Posted April 21, 2008 having problem getting my plotter to respond with my computer i can design just cant cut can any one help tried contacting bridge no response. Share this post Link to post Share on other sites
fbrgraphics 0 Posted April 22, 2008 artcut ive went to their web and downloaded new version went into zip folder and cant unzip it it shows empty folder and the seril ports or usb seems like it dont stay connected any help is OK. Share this post Link to post Share on other sites
Knobhill 0 Posted May 19, 2008 Buy it on ebay or direct? I have the same plotter won on ebay and didn't like the artcut software at all. Not very stable and in metric only. Look at the power settings on your computer and disable any settings that would turn off idle ports to save power. This fixed many problems in the past. As suggested, always set your comunication settings to the plotter default in your computer. Saves time setting and resetting up. Let us know if Bridge ever responds. Share this post Link to post Share on other sites
