Fat A 0 Posted September 8, 2008 Hi, it's me again- I just received brand new PCut, and am trying to setting up communications between my Mac and Pcut using USB. I am following the manual (provided by UScutter) carefully - but after connecting USB cable, a "found new hardware" screen doesn't pop up. I put the blue "Creation CD" into the Mac, but it doesn't start anything either. What should I do from this point?? This may be a real stupid question - but gush, I am real new to this kinda products. Does anyone know how to solve? Thanks@ Share this post Link to post Share on other sites
kenimes 42 Posted September 8, 2008 Blue Creation disk only has Windows drivers on it, so do not try to load it. Macs will not give you a New Hardware Wizard- those are for Windows platforms as well. You need the USB driver from here: http://www.ftdichip.com/Drivers/VCP.htm Share this post Link to post Share on other sites
Fat A 0 Posted September 8, 2008 Hey Ken- Thanks! So, you mean that I don't have to download the blue Creation CD?? What else should I do to set up the machine?? Is there any manual for Mac users?? Share this post Link to post Share on other sites
venice_d 0 Posted September 8, 2008 All you need to do is install the drivers that ken posted above, and set the cutter settings in your cutting application. I assume you will be using signcutx2 if you're on a mac? I made a note of all the signcut cutter settings for my pcut in a thread called "mac system profiles" Share this post Link to post Share on other sites
