dieselhog 0 Posted August 5, 2008 This thing is beating me down. I have a new Dell computer with no Serial port, thus I am forced to use the USB. I loaded SignBlazer, plugged up the USB cable to a port on the back of the machine (no hubs), I loaded the USB Driver from the blue disk, went to device manager, the usb com port said Port_#0004.Hub_#0001 on the USB Serial convertor tab, the Com port is set to COM4. Went to the cut setup tab in signblazer and set the com port to COM 4 which now says Blazer COM4 -USB Serial Port. I click cut and cut tile and it gives Cannot open the output device error initializing file I have tried a different cable, different ports, renaming ports, unpluging replugging uninstalling and reinstalling drivers. Baud rate is 9600 on machine and software. all I can cut is a small rectangle using the pause button with the unit offline. Ok computer wizards, somebody make me look stupid! it has to be a simple mistake, but I cannot see it Thanks for your help Share this post Link to post Share on other sites
new2this 1 Posted August 5, 2008 I have the same machine basically, with laptop running vista and i havent had any issues let me ck the settings i have and ill get back to you Share this post Link to post Share on other sites
kenimes 42 Posted August 5, 2008 Does the cutter say Online when you tell it to cut? Is the carriage pressing one of the red "kill" buttons? Share this post Link to post Share on other sites
dieselhog 0 Posted August 5, 2008 Carriage returns to the left hand side about 1/3rd of the way across, and the display says online Share this post Link to post Share on other sites
new2this 1 Posted August 5, 2008 My laptop crashed but i finally got it back up and running today, Ill ck everything when i get home and post my settings Share this post Link to post Share on other sites
nonabelle 5 Posted August 5, 2008 in ur cutter setup, right under the dropdown box showing ur cutter name there r two options: direct cut and cut manager. make sure direct cut is selected not cut manager. hope this helps. Share this post Link to post Share on other sites
dieselhog 0 Posted August 6, 2008 Update: Problem solved, uninstalled SB software and drivers, deleted folders, reinstalled and made 2 decals - SWEEEEEEEET. Only issue now is the blade holder, to adjust it like the forum article shows, the threaded barrell is about to fall off, and the holder cannot be pushed all the way down in the carriage, I must be missing something, or the blade shanks are to long. Thanks to all for the help Share this post Link to post Share on other sites
kenimes 42 Posted August 6, 2008 Update: Problem solved, uninstalled SB software and drivers, deleted folders, reinstalled and made 2 decals - SWEEEEEEEET. Only issue now is the blade holder, to adjust it like the forum article shows, the threaded barrell is about to fall off, and the holder cannot be pushed all the way down in the carriage, I must be missing something, or the blade shanks are to long. Thanks to all for the help Turn the end cap until it makes good contact with the little rubber O ring, and thus keeping it from rattling loose. If the blade is still sticking out too far, maybe press it down on the table a bit to make sure the blade is in all the way. Share this post Link to post Share on other sites
