nimo05
Is there an eraser feature in inkscape?!?!
Like in paint, is there an eraser feature? or how can you erase little things in inkscape?!
-Nima
There is an Undo and Redo feature, but do not think there is an erase feature.
Undo and Redo
One can undo and redo changes made to your drawing in the current Inkscape session. The Undo and Redo commands can be repeated to undo or redo multiple changes. These commands can be accessed both in the Command Bar and under the Edit menu in the Menu Bar. When accessed through the Edit menu, a description of the change that would happen if the command is selected is given.
Edit →  Undo (Ctrl-Z) (or Shift-Ctrl-Y): Undo change.
Edit →  Redo (Ctrl-Y) (or Shift-Ctrl-Z): Redo change.
New in v0.45. Multiple changes can also be undone or redone in one step by using the Undo History dialog (Edit →  Undo History (Shift-Ctrl-H)).
Two views of the Undo History dialog, both showing the drawing of a rectangle followed by changing the color and and four resizings. Clicking on any line returns the drawing to the state when the change described on the line was completed. Consecutive changes of the same type may be collapsed to one line to improve readability; the number of such changes is given on the top line of the group. Clicking on the triangle collapses (left) or uncollapses (right) the list.
All changes to a file can be undone with the File →  Revert command.
