Paisa
Does Flexi 7.5 work with Vista
Not sure it does, and if it does, SAi might not support it.
I had Flexi Starter8 running on Vista for about 7 months before it quit, and said it can no longer find the dongle. When I called SAi, they said the version is not compatible with Vista, even though it had worked flawlessly for several months. I now have the latest Starter8 which does say Vista compatible on the package.
So far i haven't seen any so called Vista compatible programs actually work 100%. You just have to deal with it.
Guest sciondrgn
I have 7.5 on my laptop with vista, no major issues but the laptop does tend to loose the usb connection to the cutter occasionally.
Version 7.6 works just well enough (vista) that you think its fine, then when you are really into a project and have not saved for a while, its seems to sense this would be a good time to crash, no worry it gives you the chance to save before closing (not) its just fooling with you and crashes anyway. I run a dual boot operating system (vista and xp). All of my sign / design software is on the xp boot side
