dbtoutfit
Digital Printed Vinyl Graphics. (using home desktop printer)
There are 120 um or thicker material available but for what I do (modelcars) it must be thin enough to form them to hollow or round parts like bodies and strong enough to not get them ripped by mechanical forces. Weigth is also and issue.
So it is a balance between them all.
Paco
How come people don't just contour-cut in one pass? You know, print out the graphics with registration-marks, laminate with clear-UV-protective laminate and then contour-cut and weed. The downside is that the paper and laminate end at the same spot, but it simplifies the process. If the laminate is well-stuck to the graphics then everything should be fine in an outdoor application.
Is there any reason this wouldn't work? I don't have a working inkjet printer to test this yet.
From my research, the way to go for home use is Durabrite Ink only available on Epson on a quality white inkjet paper like Papilion with a clear-overlaminate for max-outdoor life. The clear-overlam provides the necessary UV protection and is a physical barrier too, and apparently makes the colors pop even more.
This is the route I am going once I get my Epson Workforce 40. I've looked into the Artainium inks but I don't see any reason to use those other than for the batch application, where ink is bought in bags rather than cartridges.
Nukleon,
That is how I work for 1 year now without problems.
Paco
I saw some people talking about various vinyls. I plan to use Papilio's vinyl-paper (white) since they specifically recommend Durabrite inks for their paper. I think using the right products here should really make a difference. Combined with an overlaminate I figure this will be great for outdoor-use.
You can simply go one pass.  For indoor apps I do this, such as merchandise. But for outdoor use I do the clear layer offset to protect the edges.  Going the extra step is something I offer that my customers like that my competitors do not offer.
Eric
This is a great job!!! I have used my Epson 1280 for years on transfers and have an Epson dedicated for dyesub. I have loved them! I, however, have not tried this idea! This is a must to try, thanks for sharing the idea!  :huh:
Hi guys, I'm looking for some opinions on the best printer to buy for making the decals.  Budget roughly $100 - $200.
Thanks
Guest sciondrgn
Office depot has the Epson 1100 wide format (durabrite pigment inks) for instant $50 off, so it was only 149.99  and Frog Juice as well :thumbsup:
I've read the first 7 pages of the thread and didn't find the answer to my question so here it is....
Once the vinyl is printed on, how do you line it up on the vinyl plotter to cut the shape to match?
Thanks!!!
Looks like the Epson Workforce 1100 is back up to 200
I bought mine from Tigerdirect last weekend at 150 and now its not available from TigerDirect.
I got I guess.
Even at 200 its still worth it.
Guest HowardI
This is a great thread!
Is it possible to use something like orajet media and epson inks with the frogjuice and have good results or do you have to use a vinyl designed for inkjet use?
Keep up the awesome work guys and gals!
Howard Irwin
Support Specialist
US Cutter
425-481-3555
888-298-8143
  - Option 2
I found a epson 1400 on sale.  It comes with Claria Hi-Definition Ink.  Will this work well for the printable vinyl.  As well............do most prefer the spray on laminate ( frog juice ) instead of the sheets.  I don't have  a laminate machine, so if the spray works better I'd go that way/
thanks
Shoppiing list
Epson Workhorse 30 with Durabrite ink
CIS system with uv ink http://www.cisinks.com/continuous-ink-system-for-epson-workforce-310-with-ink-ciss-cis-p-696.html
Printable vinyl  - any suggestions?
UV top layer - any suggestions?
Laminating machine - suggestions?
What else am I missing?               I already have a vinyl cutter (Roland gx24)
Shoppiing list
I have an epson 4800 running the factory k3 ultrachrome inks, use inkjet technologies matte printable vinyl and then laminte by hand using the big squeegee and cheap oracal 200 laminate. cost per square foot is high, but works fine indoors and out. ive had some on racecars for up to a year and they still look fine. i wouldnt do anything major with it, but it works when you need something fast and dont have access to a solvent system and cut wont work.
Thanks.  I have a couple bike shops that want some printed decals.
Howard,
If you read all responses you will find an explanation that with regular dye or pigment ink printers you NEED coated inkjet vinyl.  :thumbsup:
Laminating A4 size is very simple.
Cut a 1 cm larger A4 size laminate and place the printout on a flat surface.
Peel the edge of the laminate a little off.
The released sticky side you put at the left top hand corner.
This sticks the printout and the laminate fixed to the surface.
Then take the rear backing paper of the laminate and pull it to the cross right hand side lower corner.
The cross prevents as mucg as possible air bubbles.
Take the rear backing laminate paper and place it on the printout.
Take a sqeeq and press firmly over the laminate in all directions.
If needed you can place this printout with the lamiante over the edge on a simple carriersheet (double sided lamianted poster size printout) and use it this way for contour cut.
Then there is no need to use any extra tape to contour cut it.
This is how it works for me for a year now with A4 size.
No machines needed.
A3 can be done too but you have to control it more carefully to prevent airbubbles.
Regards, Paco
I use a Epson R-1900 factory ultrachrome k2 Ink not for doing wraps.......but works
very good for alot of spot graphics.......I frog juice it 3 coats.........dry between coats.  and print on Avery Inkjet vinyl for pigment ink only.......has a special coating for pigment ink.......do not use dye base on this........as it won't hold up very long....
Guest sciondrgn
Claw, how do ya get it for 149? Told me there wasn't any 50 bucks off. Secret handshake, or something??
It might have been a weekend sale at office depot when I got mine I guess
Guest debogus
Office depot is running that sale again until the 12th of Dec
