smoovlatino 0 Posted April 20, 2007 What is the BEST way to cut two layer graphics? I'm using SignCut X2 with the 721 cutter. Thanks!! Share this post Link to post Share on other sites
Guest Terry Posted April 22, 2007 Sorry I use WinPC and Flexi. Share this post Link to post Share on other sites
Tazman00 0 Posted May 1, 2007 What is the BEST way to cut two layer graphics? I'm using SignCut X2 with the 721 cutter. Thanks!! after sending your file to sign cut, look to the right hand top corner. you should see "color boxes" of the colors of your graphic. click a color and sign cut will show only the images that are that color, and will only cut those images. do that with each color until your cutting is done. Taz Share this post Link to post Share on other sites
