ff-extreme 6 Posted June 20, 2008 Im using flexi 8.1 pro I have text that I want to do a shadow and outline. It seems to cut both items seperate text is pink outline and shadow are black so when I tell it to cut black it cuts both outline and shadow but it treats them as 2 different cuts and screws it all up. Im sure im missing something simple. I attached a sample of what I want to do airbrush.eps airbrush.eps Share this post Link to post Share on other sites
Guest fivestar Posted June 20, 2008 Did you weld the outline and shadow together? Share this post Link to post Share on other sites
ff-extreme 6 Posted June 20, 2008 If I do that then the text,outline and shadow all weld to one blur Share this post Link to post Share on other sites
Guest fivestar Posted June 20, 2008 Don't weld the text just the outline and shadow, they are the same color correct? The text is a different color? Share this post Link to post Share on other sites
ff-extreme 6 Posted June 20, 2008 Yes the outline and the shadow are the same color black, and the text is a diferent color pink. You can weld by color? How Share this post Link to post Share on other sites
Guest fivestar Posted June 20, 2008 Click Affects then combine then weld by color. Is this what you're wanting? airbrush2.eps airbrush2.eps Share this post Link to post Share on other sites
ff-extreme 6 Posted June 20, 2008 Ok I see it now! I do belive thats what I want Ill have to cut it in the AM and check. throw a couple reg marks cut the black cut the pink overlay should work! THANKS Share this post Link to post Share on other sites
Guest fivestar Posted June 20, 2008 No prob, one thing I would of done though. I would of made a filled in outline and layed to pink on top of it. Trying to butt up vinyl is impossible, because the vinyl will shrink ever so slightly over time and you will see a very small "crack" in between the 2 pieces you butted together. Share this post Link to post Share on other sites
Knobhill 0 Posted June 20, 2008 Thanx for the info. I'm learning Flexi also and haven't had this problem yet, so when I do I'll know how to fix. Share this post Link to post Share on other sites
Guest fivestar Posted June 20, 2008 No prob Knobhill, if you have any questions about Flexi just ask, I'm no Flexpert (pun intented) but I'm not too bad at it either. Share this post Link to post Share on other sites
ff-extreme 6 Posted June 20, 2008 Ok fivestar thats what I was trying to do what are the steps to do it with the fillid in outline? Share this post Link to post Share on other sites
Guest fivestar Posted June 20, 2008 You do it the exact same way you did your except change to outline to "with backing" See pic below. Share this post Link to post Share on other sites
ff-extreme 6 Posted June 20, 2008 It looks like that option is the red filed in square with the black line and not the square with the white in it? Share this post Link to post Share on other sites
Guest fivestar Posted June 20, 2008 That would be correct. Share this post Link to post Share on other sites
