lidowho 0 Posted June 3, 2008 Hi all, I'm looking for a rigid material to cut on my Graphtec CE 5000. Specs say it will cut up to 10mil. Graphtec told me I could cut thicker, if it goes thru the rollers, if I cut multiple times. I would like a material that would not bend, or be difficult to bend at, say, 10 inches high and 8 inches wide? I could do smaller dimensions if that's how to make it work. Foamcore would work, at least at the normal thickness, which is usually 1/4 inch, but my rollers can't feed that thickness. I realize this may not be possible with the cutter, but was hoping someone had some success working with something. Thanks!!! Share this post Link to post Share on other sites
Guest Terry Posted June 4, 2008 1/4 foam core? good luck with any cutter. I would not do that damage to any cutter. Share this post Link to post Share on other sites
lidowho 0 Posted June 4, 2008 Actually, what I meant was I can't do 1/4 inch. So my question is what's out there that's rigid, but thin? Sorry I didn't make that clear. Share this post Link to post Share on other sites
Guest gracewriter Posted June 4, 2008 Maybe mylar but I haven't read anyone having any success cutting it with 45 degree blades. I still haven't gotten around to trying to cut mine yet with the 65 degree blades I ordered but was told it may cut better with them. Sorry I can't be of more help. Share this post Link to post Share on other sites
