Neular 0 Posted August 8, 2022 ** Solved ** I went back into Vinyl Cutter and made the design in there and the cutting path issues were fixed. Thanks! - Second issue still a problem. Im trying to improve the following cutting path. Currently it cuts out each individual square instead of making a large square and cutting longer horizontal and vertical lines. Anyone have any clues on how I can fix this? Also my Plotter has started doing this thing where the vinyl feeds back into the spool after each finished cut instead of leaving it out. This is a pain as I have to manually feed it back out before I can cut it. any help on either of these would be appreciated. Share this post Link to post Share on other sites
darcshadow 1,626 Posted August 8, 2022 How did you create the image? If you drew it as individual squares, that's how it'll cut. If you go back and redraw it as individual lines, it should cut as you want. Share this post Link to post Share on other sites
Neular 0 Posted August 8, 2022 I created it in a photo editing software and imported it into VinylMaster. I'll see if making it in VinylMaster changes the cutting path. Share this post Link to post Share on other sites
