MKG 0 Posted August 7, 2022 Model: MH 871-MK2 Since this morning while cutting, every time cartridge arm stuck for couple of seconds specially while making a weed box. Because of this it overlapped weed box on adjust decal. When I power it on, sometime cartridge not move to the right side just make some weird noise. I already changed the blade. put some oil on the belt. Also, opened from left side to visually inspect but it looks good. Any suggestions to resolve this issue. Thanks Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 7, 2022 " weird noise " -- like a grinding noise? Motherboard. Share this post Link to post Share on other sites
darcshadow 1,625 Posted August 8, 2022 A grinding noise would be the motor trying to move the carriage and not able to. Can you slide it by hand? Do you feel any ruff spots when you do that? Sounds like something is blocking the movement. You didn't put oil on the actual belt did you? The belt needs friction with the rollers to work. Oil the axis of the rollers but keep the belt dry. Share this post Link to post Share on other sites
