Guest Jaywindscreen
721 cutting plotter
Guest Jaywindscreen
Hi All - please help !
I have a 721 cutting plotter I'm using with SB Elements.
Firstly it seems to want to cut everything in mirror (even after I've ticked or unticked the mirror box).
Also it doesn't want to print along the roll, just crossed it ???
A friend mentioned it could be because the X and Y Axis are incorrect ?   I'm lost here !
Need some more info.
  • Has it ever worked?
  • How are you connected to the cutter, USB or Serial?
  • Do you have the correct drivers loaded?
  • What cutter do you have selected in SB?
  • Does the cutter's test function work correctly?
Just rotate the entire cutting machine around.
:ph34r:
No seriously, how are you connected to the computer? USB?
Give us some more details, we're not sitting there in the room with you.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
