1clo1 4 Posted July 7, 2022 hello everyone, I have a file with 2 colors, red and white, it is separating the red into multiple files, how do I cut it with the red as one file so I don't waste so much vinyl? I tried to group the file and it still shows it as separate cut files, welding makes it all 1 file and cant cut separate colors. any ideas to get the red as one cut file? Quote Share this post Link to post Share on other sites
haumana 1,220 Posted July 10, 2022 not quite understanding the question or issue. If you select the color red to be cut, then everything that's red will cut as long as it fits in the design space and the media size at you set in your software. It will also preserve the layout so if you have a 36" design with a single red item at the very left, and a single red item at the very right, the cutter will jog all that vinyl between the two different elements. If you have multiple red items, but it's not cutting all of it when you send it to the color, make sure that all the elements are actually the shade of red, because the software will know if it's RGB Red 255 vs RGB R250, and it will only cut the one that you designate. <- That's just an example. Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted July 11, 2022 I think he/she i's using the term files in place of shapes, and they would like to move the shapes around to minimize wasted vinyl. You could grab all the red shapes and do an auto arrange, that would be it into a grid pattern. You would then have to rebuild your design during the install to put everything in the correct place. Quote Share this post Link to post Share on other sites
