Loftipop
Cloudy to specific blur spots on Mugs?
Hello, I've been running into problems with these mugs in particular for a year now. Throwing away almost half.
There's a bit of clouds going on in the green sometimes. And then some spots it will blur, other areas are fine. Sometimes I'll get faded white splotches. I cannot seem to recreate it. It just happens randomly.
I'm using Hix (who can't seem to figure it out either.) Using their wraps on their 24x14 conveyor oven. Also seeing this happen with thick bold letters using dark colors on other mugs. I'll use new wraps and old wraps. Same problem.
Please, anyone, help.
These are the settings:
11oz and 15oz ceramic mugs
400 F
6.7 fan speed
11:48
Have you tried to dip them in warm-ish (room temp) water after pressing, to stop the sublimation process?
Thanks for replying! Our conveyor oven comes with a cooling fan that hits immediately after heating. I guess I can snag it out before it hits the fans and test it. Have you seen this type of clouding when you don't dip your mugs?
where are you getting your mugs?   coating has to be spot on even = best mugs I used over the years were from Marck in toledo ohio - cost more but the mugs were always perfect and very durable unlike some of the cheaper ones I purchased that had uneven coating and many broken handles
@Dakotagrafx Thanks for replying! Good point. We get our mugs from Orca which I believe they are on the higher spectrum? https://www.photomugs.com/collections/orca-ceramic-mugs
We've noticed that enamel camp mugs have literally no issues but 11oz ceramic come out the worst. 15oz ceramic are also iffy but better than the 11oz.
I have some Gator mugs that I can test out but I'll see if I can grab some of these Marck mugs as well.
