Skibo 0 Posted February 6 I recently purchased Vinylmaster cut for use on my newly purchased Graphtec CE5000, I am getting a HP-GL error. I tried a trial version of easy cut and it had an option to set HP-GL / GL-GL in the program , the trial version worked fine . I purchased Vinylmaster due to good reviews. The key pad on plotter is acting up so I cant set there . I am asking if there is a provision in Vinylmastercut 5.0 to change settings. I tried hard reset on plotter , and took side panel off and removed and re plugged ribbon cables from key pad in an effort to clear up issues . any help would be greatly appreciated. Quote Share this post Link to post Share on other sites
Camel 7 Posted February 6 Yes, in settings: Open Vinyl Spooler: Menu: Cutter/Configure Cutter/Edit/Advanced Settings... go to the "Commands" Icon, over on the right is "Device Language" click the "+" and then scroll through the list. Quote Share this post Link to post Share on other sites
Camel 7 Posted February 6 Also Graphtec offers desktop software and you can change the language in there, which is where you may need to be. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,669 Posted February 6 You can go to the Graptech site and download the Graphtec cutting controller for the CE5000. You can change the Command there. I do all of my cutting/changing settings from the Graphtec Cutting Controlller. Your vinyl cutter must be sitting ready to cut, before the Cutting Controller will open. It must be on Controller setting. Below is an example of mine. Set up for my vinyl cutter. You can see COMMAND at the left bottom, click it. First you must go to ADVANCED SETTINGS. Quote Share this post Link to post Share on other sites
Skibo 0 Posted February 6 Thank you , it is now cutting. This forum is awesome Quote Share this post Link to post Share on other sites
Camel 7 Posted February 6 Thanks for reporting back, enjoy. Quote Share this post Link to post Share on other sites
Skibo 0 Posted February 6 I have the controller loaded, now my journey begins. All of you're fast responses saved the day Quote Share this post Link to post Share on other sites
