mhristau 0 Posted January 26, 2022 What am I doing in Illustrator that causes these diagonal lines (travel instructions) to become cut lines in Cricut Design Space? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 26, 2022 Check out a craft forum or Cricut forum. Most people that answer questions here use full sized vinyl cutters and software for those vinyl cutters. Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 26, 2022 I don't have a cricut so I'm just guessing here, but how are you saving/importing the files? My assumption is EPS files, and I don't know that the EPS format supports "travel lines". I suspect those my be an AI only kind of thing. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 16, 2022 On 1/26/2022 at 11:29 AM, mhristau said: What am I doing in Illustrator that causes these diagonal lines (travel instructions) to become cut lines in Cricut Design Space? The screen shot is NOT adobe Illustrator. Whatever you are seeing there is being inserted by the Cricut interface. I would assume it is somehow sending some interface instructions meant for your cutter that are transposing as cut line? Just a guess... I would suggest trying a newer or older version of your saved AI file or even change the file type from AI to SVG or EPS or whatever the Cricut program likes. My cutter interface prefers Adobe Illustrator version 8 which is a much simplified legacy version. There are a LOT of extra "doodads" especially in the CC version of AI that may be complicating your file. Share this post Link to post Share on other sites
haumana 1,220 Posted February 16, 2022 On 1/26/2022 at 8:29 AM, mhristau said: What am I doing in Illustrator that causes these diagonal lines (travel instructions) to become cut lines in Cricut Design Space? "What am I doing wrong?" is a little hard to troubleshoot, when we don't know what and how you're doing things. Would be helpful to know what version of AI you're using, and how you're exporting/importing to DS. File format, etc. Have you tried to export it in another format that is DS friendly? What formats are DS friendly? Share this post Link to post Share on other sites
