1clo1
Background options
Hello everyone, I'm looking to vector an American flag to cut on HTV, the image is RED, WHITE, and BLUE, however when I vectorize the image I can't get the white to show it is the color of the background. I have tried the contour cut and outline option and neither give the effect I need. any ideas on how the accomplish this?
Thanks in advance
You can recolor your white stripes to something else, you're using will vectorize it, or just add your own line pre or post vectorizing.
  • Like 3
Another option would be to complete the vector with only the red and blue portions. Once completed, create a copy of that vector and insert a rectangle shape in the exact dimensions as the copied vector right behind it. Once you have them perfectly aligned, select both objects and use the "Punch Out" operation (right-click when both objects are selected > Shaping > Punch Out). You'll be left with the area that would have been the white color. Then combine that with the Red and Blue vector and you should be set.
Hopefully, that helps!
Good luck, -Russ
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
