cookbook202
Titan 2 plotter rest for cutting
I have only used this Titan 2 a couple of times and has been a year since last use. Recently I created a stencil and I tried to make an adjustment to rotate/ make the numbers larger. now the cutter blade is all the way down and cuts and pushes the stencil paper into a mess. Also the blade gets real hot. Can anyone advise. THX
blade getting hot would be hard to do , I would think .  first take your bladeholder out and put a drop of sewing machine or reel oil in there and make sure the blade spins freely.  Make sure you follow skeeters instructions on setting you blade depth
