WildCorral
Installing art straight
Newbie. In your experience is a decal easier to install for the customer if it has a border incorporated in the design, OR, is a less defined edge more forgiving of “crooked” installation?
Greatly depends on what/where it's being installed. There's no generic answer. In some cases having a border or some sort of straight edge is very handy, others it draws attention if not lined up perfectly.
  • Like 4
I have learned to be very precise when I do a final clean-up cut after applying the app tape. I use one of the see through craft ruler (Fiskars) and I cut as straight and square as possible. I usually try to use a common offset like a half inch around each side. (enough to be able to hinge without overlapping the vinyl with my masking tape.  I have found that being able to use the outside of the masked decal to align with is easier than trying to see through the app tape and figure out if it's hanging straight or not. Having a nice square decal works wonders on simple things like flat glass and signage.
If it's going on a car, keeping it looking straight is a whole other art form with all the wild body lines these days. I usually find a window or door bottom or something like that to match and hope for the best.
Another worthy piece of newbie advice... go find an Auto Paint & Glass supply store and splurge on some PG grade masking tape.(3/4" or 1")  I'm pretty sure the PG stands for Professional Grade. It adheres about 10 times better than the regular stuff you get at normal stores. It also comes off clean without leaving residue. It's not cheap but you'll use less and when the wind catches an edge and tries to take off with your work about the time you have the backing off it just may save your day.
  • Like 2
